VWVortex.com - Start-Stop System?
    Results 1 to 7 of 7
    Thread: Start-Stop System?
    1. Junior Member
      May 7th, 2005
      St. Andrews
      Audi A3 2012
      05-23-2020 06:33 AM #1
      Good Morning,
      I hope everyone is fine these days!
      I purchased a new VW Golf R last November, it now has only 2689 km. on it.
      When I first purchased the R the Start-Stop system worked fine. A few weeks ago the Start-Stop system will not work!
      In the instrument panel it shows it is activated.
      I phoned the VW dealer told them the situation and they told me they were not sure, maybe you have not driven it far enough.
      I read in the manual that the Park Pilot system should be deactivated, air conditioner is off etc.
      I deactivated these.
      Shouldn't my R work with the the settings I program it to?
      I noticed in the car settings that I can reset the R to its Factory Settings would that help?
      Thank you.
      Rosies
    2. Remove Advertisements
      Advertisements
      Dec 18th, 2015
      GA. USA
      '19 ORYX MK7.5 .:R
      05-23-2020 10:51 AM #2
      Check your battery. If voltage is too low, start/stop will not work.
    4. Member David9962000's Avatar
      Feb 1st, 2011
      California
      MK7 GTI
      05-23-2020 10:51 AM #3
      The start/stop is based on a few factors before it works like battery voltage, A/C, water temp...
    5. Remove Advertisements
      Advertisements
    6. Member
      Oct 14th, 2014
      Fort Wayne, IN, USA
      1996 BMW M3; 2015 Golf R; 2018 Audi Q5
      05-23-2020 11:02 AM #4
      What’s funny is that most people complain about start-stop working, not about it not working.
      Neil
    7. Semi-n00b
      Apr 17th, 2020
      Delaware
      2019 VW Golf R DSG Spektrum Edition - Cliff Green
      05-23-2020 12:23 PM #5
      Quote Originally Posted by NeilCM View Post
      Neil
      No ****! I hate when I forget to turn it off...
    8. Junior Member
      May 7th, 2005
      St. Andrews
      Audi A3 2012
      05-23-2020 12:27 PM #6
      Hi Neil,
      At times I don't like it when my R shuts off because of the Start-Stop system!
      I just want my car to work like it is suppose too.
      Thank you.
      Rosies
      Apr 8th, 2018
      USA
      2018 Golf R
      05-23-2020 12:47 PM #7
      If you don't mind starting from default settings, you might as well try resetting everything to factory settings. Just make sure you note the important settings you want back later on.
      Also, Start/Stop is deactivated when you are in Race suspension and Sport transmission. I think both of those being "on" will prevent it from operating as that's what I finally figured out to disable Start/Stop for me every day. I have it set to be in Race all the time and, every time I shift out of Park, I automatically double tap the shifter back to put it in Sport. Start/Stop has not activated since. That might be due only to Sport mode but I don't think about it anymore. It's off and that's fine by me.
      So check that next time you're out. If you're in Sport, put the car into D instead.
