VWVortex.com - 13' TT-RS UM Stage 2 Fuel cut issues
    Results 1 to 2 of 2
    Thread: 13' TT-RS UM Stage 2 Fuel cut issues
    1. 06-19-2020 07:44 PM #1
      Hey guys, according to some initial research this appears to be a common issue amongst the RS community when running high boost.
      From the intel that I have gathered thus far, the pump/controller overheats and can no longer maintain the pressure needed.
      CTS said This fuel cut seems to be a more-or-less common occurrence with MK2 TT-RS and usually is fixed by replacing the low pressure pump or some customers have installed a TorqByte fuel pump controller. However, torqbyte required some sort of custom coding to make it work with the TT-RS. I do not have much detail on that unfortunately.
      The fuel cut always seems to happen under WOT between 5-6k rpm.
      The dealers suggested route is to first change the fuel filter, then inspect the HPFP to visually inspect the spring and plunger.
      I've seen a few guys upgrade to either a Loba or an Autotech HPFP.
      There was a vague post about "wiring", and if the above does not fix the issue then replacing the LPFP as a last resort.
      I just thought someone here might have experienced the same issue or similar and could best direct me on the fix.
      Thanks in advance
      Apr 7th, 2014
      MD
      '07 A3 3.2 Quattro // '12 TTRS
      06-30-2020 11:46 AM #2
      Did UM not give you any troubleshooting info?
