VWVortex.com - Cruise control - Tempomat Passat B5 3B2 1.9TDI AFN January 1997
    Results 1 to 3 of 3
    Thread: Cruise control - Tempomat Passat B5 3B2 1.9TDI AFN January 1997
    1. n00b faires's Avatar
      Jun 13th, 2020
      Porto - Portugal
      1997 WV Passat B5 3B2 1.9TDI AFN sedan
      06-21-2020 06:37 AM #1
      Hi All,.
      I would like to retrofit cruise control - Tempomat in my Passat B5 3B2 1.9TDI AFN January 1997 (with low cost aftermarket, ebay like parts...)
      It's driven by my daughter, I take care of it as an hobby, I already got lot of info on how to do it, but I have the following doubts:
      There are mainly 2 types of stalks/switches for selling, 8L0 953 513 A and 18G 953 513 A, and both offered as a packge with same wire loom 1J1 970 011 F
      (I noticed now that I don't have yet 5 post, so I can't post links, had to remove them and leave only text...)
      8L0 953 513 A (main button: +/RES/ON/OFF)
      "https://1drv.ms/u/s!AuB29YHJMk-3hIhNK4D_4ycRHQJQHQ"
      18G 953 513 A (main button: ON/OFF only)
      "https://1drv.ms/u/s!AuB29YHJMk-3hIhODFpwzp-ZYeaGwQ"
      1J1 970 011 F
      "https://1drv.ms/u/s!AuB29YHJMk-3hIhP05q33zFyAbrTcA"
      I think it should be the 8L0 953 513 A, but as it looks both can use the same wiring, can I instead use the 18G 953 513 A ?
      Or none of them will work with the wiring 1J1 970 011 F ?
      In that case, I could make the wiring myself if I could get the schematics or the info on where to connect the pins (or signals) of the cruise control switch...
      Engine ECU Bosch MSA 15: 0 281 001 555/556 (VW id: 028906021DT)
      VIN no: WVWZZZ3BZVE035252
      May 9th, 2002
      Grapevine, TX
      01 Passat 4MO Wagon, 6sp manual and 1.8T swap. 05 Golf 2.0
      06-21-2020 05:42 PM #2
      They should both work. I prefer the 18G as it's easier to adjust speed with a fingertip. I've upgraded to the 18G on my Passats, but I already had CC on them.
      2019 Tiguan SE 4Mo Orange, temporarily stock. 2001 Passat 4Mo wagon, 1.8T/6sp swapped, Konis, coilover sleeves, A6Q H+R Race springs.
      2005 Golf GLS, 2.Slow, Auto, GTI suspension, sways.
      2001.5 Passat GLX V6, stock. (son#1), 2000 Passat GLS V6 fwd Tip wagon, stock (son#2)
    4. n00b faires's Avatar
      Jun 13th, 2020
      Porto - Portugal
      06-29-2020 08:17 PM #3
      Thank you. As the upgrade to 18G worked without any modification, with the same wiring and connectors I suppose , it should work for my Passat also. I also prefer the 18G.
      Thanks again.
      Fernando Aires
      Porto - Portugal
      VW Passat B5 3B2 1.9TDI AFN sedan 2017 Jan.
