VWVortex.com - Plug and play amplifier (NOT Match)
    Results 1 to 6 of 6
    Thread: Plug and play amplifier (NOT Match)
    1. Member speed51133!'s Avatar
      Aug 5th, 2002
      alexandria va/milwaukee wi
      02 audi tt 225 / mk3 jetta /audi 5000s turbo
      06-29-2020 12:30 PM #1
      https://enfigcarstereo.com/ENFIG_PNPAMP_VW16.html
      Just got off the phone with Enfig. They told me it should work fine with the Atlas as they have confirmed it works with the Tiguan. The kit has all the harnesses for a plug and play addition of https://www.pioneerelectronics.com/P...eries/GM-D1004
      The amp alone costs 150. Seems like a decent value. Anyone know what the non fender audio system has in terms of Ohms and RMS power?
    3. Member mhjett's Avatar
      Oct 16th, 2000
      Grand Rapids, MI
      2018 VW Atlas SEL 4Motion R-Line 3.6, 2008 VW Jetta SE 2.5
      06-29-2020 02:19 PM #2
      Sorry, don't have the answer but am curious about that kit -- does it include the amp? It's not clear from the webpage...
      Looks like the Pioneer GM-D1004 is discontinued now?
    4. Member speed51133!'s Avatar
      Aug 5th, 2002
      06-29-2020 03:16 PM #3
      Yes it has the amp. Talked to them. They have like 8 amps in stock. It is discontinued
    5. Remove Advertisements
    6. Member mhjett's Avatar
      Oct 16th, 2000
      Grand Rapids, MI
      06-30-2020 10:57 AM #4
      Nice. Sounds like it'd be a great plug and play upgrade.
      Probably will be hard to find the RMS power and ohms of the stock system. Did you check the audio system manual that came with the car?
      I'd bet the only way to get impedance for the stock speakers is to pull the harness and use a multi-meter on the pins.
    7. Member speed51133!'s Avatar
      Aug 5th, 2002
      06-30-2020 11:05 AM #5
      they use the harness that comes with the amp to make the PnP harness. I am absolutely sure they could do it with another amp (if they want to is another story). There are like 3 or 4 very similar, almost exact, amps by Sony, Alpine, Kenwood, etc. Does Enfig come to the forums?
      EDIT, just ordered the enfig kit. will post how it installs and works.
    8. Member mhjett's Avatar
      Oct 16th, 2000
      Grand Rapids, MI
      06-30-2020 02:26 PM #6
      Quote Originally Posted by speed51133! View Post
      Great, post an update on the install and your impressions.
