VWVortex.com - Remove front brake rotors rusted to hubs?
    Results 1 to 17 of 17
    Thread: Remove front brake rotors rusted to hubs?
      Aug 31st, 1999
      confluence, Snake/Clearwater
      Rolls Rice yalu cloud, pink 59 DeSoto with leopard-skin seat covers
      07-26-2020 01:29 AM #1
      These are the FS111 brakes on a 2003 Jetta. Don't know when they were last removed, but they are rusted tight now. The disk retaining screws are stuck, too. Drilled off the head of one retaining screw, but the rotor is like the rock of Gibraltar—it ain't movin!
      Anyone have good ideas on removing rotors rusted to the hubs?
    2. Remove Advertisements
      Advertisements
    3. Member MauiJettaUte's Avatar
      Sep 6th, 2018
      Maui, Hawaii
      2004/Volkswagen/Jetta
      07-26-2020 01:30 AM #2
      Rubber mallet and just swing away
      Sent from my SM-N975U using Tapatalk
    4. Member
      May 30th, 2015
      Fort Walton Beach, FL
      2005 mk4 Jetta 2.0L
      07-26-2020 07:51 AM #3
      Look for a threaded hole on the face of the rotor. I don't recall the size, m7 or m10 maybe. Breaker bar and socket. Screw in and it lifts rotor off.
      Sent from my SM-S727VL using Tapatalk
    5. Remove Advertisements
      Advertisements
    6. Member
      Aug 31st, 1999
      07-26-2020 08:58 AM #4
      Don't recall any threaded hole on the rotor of the FS111 brakes, but I will check carefully. That would be great!
      Unfortunately, that was wishful thinking. No threaded holes on these rotors…
      And consider the term "stealership" often used on Vortex. Threading holes would cost VW at least a minute of manufacturing time, but what's worse, it would reduce the time VW service departments could use in billing for brake service. VW's—not service friendly.
    7. Member Brake Weight's Avatar
      Jul 27th, 2006
      Southern Miss
      2004.5 f23 GLi, '99 Taco on 33s
      07-26-2020 10:04 AM #5
      Water. Soak all the oxidation with water and let it sit/soak. Use a spray bottle and a mixture of salt water if it’s absolutely stuck with no wobble. Hair of the dog type scenario.
      Quote Originally Posted by Anony00GT View Post
      Who's the idiot that deleted the EVAP solenoid?
    8. Member xspeedracer's Avatar
      Sep 23rd, 2002
      Davis
      2003/VW/GTI1.8T
      07-26-2020 10:17 PM #6
      Get a big hammer and whack the rotor hat till it breaks loose
      2003 MK4 K&W V3 clubsport suspension, GC Camber plates, Shine Racing rear swaybar, 3"TB Forced-motion exhaust, Meistro Tuning, S3 strut bar, Baily DV, Modified Factory Airbox, VF engineering Motor mounts, TT front Brakes, USRT stage 2 Subframe and lower control arms.
    9. Member MauiJettaUte's Avatar
      Sep 6th, 2018
      Maui, Hawaii
      07-26-2020 10:20 PM #7
      Quote Originally Posted by xspeedracer View Post
      I recommend it too, but I guess he couldn't get it off?
      I had some rusted rotors before couple huge swings and it came out.
    10. 07-26-2020 10:34 PM #8
      Brass hammer always does the trick.
    11. Member xspeedracer's Avatar
      Sep 23rd, 2002
      Davis
      2003/VW/GTI1.8T
      07-26-2020 10:40 PM #9
      Get a bigger hammer
      Apr 28th, 2017
      VT
      2003 JETTA GLI 24V VR6
      07-26-2020 11:02 PM #10
      My trick is to loosen the lug bolts a bit, then drive over big bumps and swerve around. Always breaks them loose
      As soon as you hear it pop loose and wobble, get out and tighten the bolts, drive home. Dont go over 30 mph, and avoid crowded roads
    13. Member
      Aug 31st, 1999
      07-27-2020 07:41 AM #11
      Big dead-blow hammer did the job after an overnight soaking with Gibbs penetrant. Imagining a damaged rotor, I didn't want to use an iron sledge…
      Cheers to Showroom special for his novel idea!
    14. Member
      Jul 17th, 2001
      Philly burbs, PA
      2015 GTi, 2014 S4
      07-30-2020 08:56 PM #12
      Quote Originally Posted by MauiJettaUte View Post
      Agree.
      If you are sure that set screw is all the way out of the way.... then hit the edges of the hub with some WD-40, put in a lug nut part way so when the rotor does break loose it doesn't come flying off on your foot.
      Grab a hammer and whack away.
    15. Member Polini33's Avatar
      Feb 5th, 2014
      Kitchener/Waterloo
      08-01-2020 01:12 PM #13
      manpower always wins, theres no other way. smash
      2000 VW Golf GTI - 1.8T
    16. Member
      Jul 22nd, 2012
      Florida
      81 scirocco 1.6 diesel, 86 golf 1.6D, 85 300TD, 2003 Golf ALH
      08-01-2020 10:25 PM #14
      A stuck rotor is nothing compared to a stuck rear drum. Worst case you'd have to drill out a stripped set screw, get new one at the hardware store.
    17. Member
      Aug 31st, 1999
      08-01-2020 10:31 PM #15
      sgnim is right as far as he goes. BUT he's in the realm of theory. Has anyone seen a stuck rear drum on a Mk4? I thought not.
    18. Member
      Jul 22nd, 2012
      Florida
      08-01-2020 11:31 PM #16
      haha
      I had a datsun 620 pickup with drums in the front. Four-wheel drum brakes , 1976.
    19. 08-02-2020 11:49 PM #17
      Whacking with a non dead blow hammer can trash wheel bearings. Ask me how I know.
