VWVortex.com - Address 7E8: 1 Fault Found: P0133 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
    Results 1 to 11 of 11
    Thread: Address 7E8: 1 Fault Found: P0133 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
    1. Member TablaRasa's Avatar
      May 11th, 2008
      Central NJ
      See Signature Line
      07-31-2020 01:40 AM #1
      My cousin called me about the CEL popping on her 2019 SEL. She has 3000 miles on it. I scanned it and the code P0133 came out. I didn't clear it but the CEL went away . I told her to make an appointment and show the code. Car was hesitating and bogging down. Anybody come across this? With the CEL off, would dealer not do anything? I'm afraid it might be a start of what is to come so hoping they'll do something. Feel bad as I introduced VW to her ( her first one) and feel embarrassed it happens this early in the life of her car. I know warranty is there but still for a first timer, it is not a good impression
      Sent from my J8170 using Tapatalk
      CURRENT: 1987 Golf Cabriolet Alpine White (QQ plates applied)
      MKV R32 (#959) 4mo Candy White
      B6 Passat Wagon VR6 4mo Mocha Brown Metallic (Daddy Mobile)
      Atlas SEL-P 4mo Plat. Grey (Wifey's Twin Mobile)
      PAST: MQB Tiguan SEL-P 4mo (Traded); 02 Toyota Matrix XRS, 93 Corolla, 98 Camry
    2. Remove Advertisements
      Advertisements
      Jan 12th, 2013
      PA
      '73 Beetle (very slow), 2018 Jeep Compass Manual (less slow), 2019 Jetta GLI Manual (least slow)
      07-31-2020 01:49 AM #2
      Quote Originally Posted by TablaRasa View Post
      My cousin called me about the CEL popping on her 2019 SEL. She has 3000 miles on it. I scanned it and the code P0133 came out. I didn't clear it but the CEL went away . I told her to make an appointment and show the code. Car was hesitating and bogging down. Anybody come across this? With the CEL off, would dealer not do anything? I'm afraid it might be a start of what is to come do hoping they'll do something. Feel bad as I introduced VW to her ( her first one) and feel embarrassed it happens this early in the life of her car. I know warranty is there but still for a first timer, it is not a good impression
      Primary oxygen sensor. Anything been disconnected, or any work under the hood done? If you didn't clear the code, it should still be in memory.
      Sent from my SM-G975U using Tapatalk
    4. Member TablaRasa's Avatar
      May 11th, 2008
      Central NJ
      See Signature Line
      07-31-2020 08:30 AM #3
      Quote Originally Posted by burgsprinta View Post
      No, she hasn't been in the shop or anything. It has a little over 3k miles and is yet to do the 10k service. The CEL is gone now but yes the error still comes up when I scan it.
    5. Remove Advertisements
      Advertisements
    6. Member
      Jan 12th, 2013
      PA
      07-31-2020 11:34 AM #4
      I'd get that to the dealer right away, because if this is happening, her fuel trims are going to be all screwed up, which could cause much more damage. The first thing I'd check would be the oxygen sensor though. Maybe it's bad, and sending bad information back to the ECU. Weird to happen on a 3,000 mile car though.
    7. Member TablaRasa's Avatar
      May 11th, 2008
      Central NJ
      See Signature Line
      07-31-2020 12:03 PM #5
      Yes, her appointment is August 4. That was the earliest appointment.
      Exactly , 3000 is too early! I feel bad. Hopefully it is not anything big
      Sep 15th, 2019
      Western NY
      '19 35th GLI M6
      07-31-2020 05:40 PM #6
      Probably just a bad O2 sensor. I get the same code but for my rear O2 due to my spacer.
      Jan 12th, 2013
      PA
      07-31-2020 05:45 PM #7
      Quote Originally Posted by 35thGLINoob View Post
      Yeah, but it it's odd for the oxygen sensor go bad on a completely stock car that's never been touched, with only 3,000 miles. You can't drive with a bad primary O2 though. Well you can, but not for very long, and not wisely.
    10. Member
      Sep 15th, 2019
      Western NY
      '19 35th GLI M6
      07-31-2020 05:56 PM #8
      Infant mortality. Happens all the time with various electronics, just so happened to be the O2 on that specific car. I'd bet after it's replaced the car will run problem free for years after.
    11. Member TablaRasa's Avatar
      May 11th, 2008
      Central NJ
      See Signature Line
      08-01-2020 09:18 PM #9
      Hope so. But would they even replace it that the CEL is not there at the moment. I know it's in the memory since when I scanned it, it's there. But yeah , I'd feel more comfortable they do change it. For her sake.
      Jan 12th, 2013
      PA
      08-01-2020 09:20 PM #10
      I'd insist that they do. But as a last resort, I'd do it myself. The sensor is not that expensive, and it's easily accessible
    13. Member TablaRasa's Avatar
      May 11th, 2008
      Central NJ
      See Signature Line
      Today 11:48 AM #11
      She went today and they will replace it. They have to order the part first though. Man, that is sad for parts to be failing at that mileage. But glad it is gonna get sorted out.
      But I know she is saying to herself "why did I listen to my cousin in getting VW" SMH
