VWVortex.com - Bringing Back Dull Single Stage Paint
    The Car Lounge
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 45
    Thread: Bringing Back Dull Single Stage Paint
    1. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      87 Jetta, 88 Cabby, 91 Jetta, 15 GSW, 19 Tiguan
      08-01-2020 10:06 AM #1
      The paint on my '91 Jetta is chalky and I'd like to begin the process of bringing it back. I have used Rubbing/Polishing compound in the past with mixed results and wonder if anyone in here has any tips and or tricks.
      I don't currently own an orbital buffer and I am hesitant to use one because it seems that is what happened to our Cabby paint before we bought it. The angles and hard lines are down to primer because of taking too much of the paint off.
      Any advice is appreciated. I'd like to do it right the first time and would like it to last as long as possible. I've considered going to a professional but I wonder how many detailers have a good handle on the process since these cars are so old now.
    2. Remove Advertisements
      Advertisements
      Oct 22nd, 2007
      Syracuse, NY
      982, F22, E88, etc.
      08-01-2020 10:33 AM #2
      Oof, that's always a tough one. I don't have any solutions, but I am in for Mk2 content and would like to know for when I inevitably get one.
    4. Member
      Feb 28th, 2007
      Northern VA
      1979 Cadillac DeVille 3 speed /2020 Acura RLX Hybrid/ 2019 Corvette Grand Sport 7 speed stick
      08-01-2020 10:41 AM #3
      I would not use rubbing compound especially on thinning paint
      Unless you use an aggressive abrasive, random orbital machines are safe and a great tool for polishing with the correct polishes
      If you do not use a machine perhaps try a synthetic clay to clean paint and Griots Garage 3 in 1 liquid cleaning Wax. It has a mild cleaner, will add gloss and protection. If this does not bring up the paint then you probably need to do a multi step polish with a random orbital.
      Jul 31st, 2009
      2018 Hellcat Charger, 993 C2, 2005 GX470
      08-01-2020 11:37 AM #4
      I second the advice that a random orbital is very unlikely to do any serious harm if you keep it moving. I would also add that if you went to an experienced detailer they shouldn't have any issues working with your paint and will communicate any concerns they have after inspecting the vehicle.
    6. Senior Member DonL's Avatar
      Feb 28th, 1999
      SE Michigan
      A blue oval and a bowtie. Domestic swill.
      08-01-2020 12:42 PM #5
      I thought you wanted to start a trend of matte finishes on older Dubs.
      "I get my kicks above the waistline, sunshine."
    7. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      08-01-2020 01:03 PM #6
      Wash, clay, then a random orbital with good pads and product will be totally safe.
    8. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      08-01-2020 02:23 PM #7
      The thread title made me think that we should start requesting that manufacturers bring this finish back to current automobiles.
      Chris
      | 20 Ram | 13 Altima | 00 Tahoe | 94 Integra GS-R | 74 SuperBeetle | 62 Ford Unibody |
    9. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      08-01-2020 02:39 PM #8
      Didn't think of it that way.
      Thanks for the advice guys. Guess I need to shop for an orbital. Any recommendations on a good brand? I might practice on the Cabby first and then hit the Jetta.
    10. Member
      Feb 28th, 2007
      Northern VA
      08-01-2020 03:45 PM #9
      Quote Originally Posted by UncleJB View Post
      JB
      I own 2 Griots Garage Random Orbitals. I think my newest one is about 5 years old. I believe they are made by Porter Cable. I would recommend the long cord option. Griots has great customer service and if you call them their associates are very knowledgeable and can offer great assistance. They can probably give you better advice on which of their liquid car care products to use on your Vdub. The foam pads are washable and can be re-used a few times.
      For what is worth, my 1979 Cadillac I inherited 17 years ago from my neighbor and friend's parent's still has the original 41 year old GM lacquer paint on it, no bare spots. I have detailed this Caddie since new when I was in High School. Primarily Griots products used with the orbital for the past 17 years or so.
      Have Fun!
      https://www.griotsgarage.com/product...rPicks&from=fn
    11. Member mhjett's Avatar
      Oct 16th, 2000
      Grand Rapids, MI
      2018 VW Atlas SEL 4Motion R-Line 3.6, 2008 VW Jetta SE 2.5
      08-01-2020 04:11 PM #10
      Is that an 8v Wolfsburg edition?
      I have the Flex 3401 DA orbital, made in Germany, and it's fantastic:
      https://www.amazon.com/Flex-XC3401VR...001DB0NVG?th=1
    12. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      08-01-2020 04:16 PM #11
      Quote Originally Posted by CadiGTi View Post
      JB
      Have Fun!
      Good tip thanks.
      Quote Originally Posted by mhjett View Post
      It was - now it is a turbo diesel.
      Nice I will look into that one as well.
    13. Member
      Apr 23rd, 2020
      Midwest
      77 Porsche 911S, 95 Audi S6 Avant, 04 Beetle Turbo S
      08-01-2020 04:20 PM #12
      The missing paint on the edges of your previous car was not due to buffing, it was due to some moron NOT KNOWING WHAT THEY ARE DOING.
      Can you burn through your paint w a buffer? Sure. You could also forget to put your drain plug in and ruin your engine if you changed your own oil.
      Easy solution: Don't do that.
      I have a harbor freight special buffer, 6" pad. Got a wool pad for a heavy cutting, and some foamies for finishing. For compound, man... I cannot recomment 3m PerfecIt enough. I've tried using everything meguieres has, and I hate all of it. Also, while you're at HF, pick up the 3" pneumatic buffer gun, should be around $20 or so. Do the big panels w the big buffer, then use the 3" pnuematic one on smaller area, near headlights, etc.
      Don't press down. Let pad do the work. Don't stay in one spot too long, paint will get to hot. Buff up to edges, and make sure if you get near an edge, the rotation of the pad is going OFF the edge. If the pad is going TOWARDS the edge, it can catch can pull the buffer into the edge burning the paint.
      When I had my s6 painted, I wet sanded and buffed the whole car myself. Had never done it before. Was not hard at all. Seriously don't understand why people spend $1000's on paint correction, it was so freakin easy once you get the hang of it. >shrug<
    14. Member
      Apr 23rd, 2020
      Midwest
      08-01-2020 04:21 PM #13
      Also, I use that 3" pneuamtic buffer pretty often. Makes quick work of headlights, taillights, plastic panels on poewrsports equipment, etc etc etc.
    15. Member
      Apr 23rd, 2020
      Midwest
      08-01-2020 04:24 PM #14
      Before after 86 civic si
    16. Member
      Apr 23rd, 2020
      Midwest
      08-01-2020 04:24 PM #15
      Somehow those are bAckwards. You get the idea tho. Brings sexy back.
    17. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      08-01-2020 04:28 PM #16
      Wow nice!! Thanks for the info too.
      I just realized DeWalt has a 20V tool. I like the idea of not having to mess with a cord.
    18. Member
      Apr 23rd, 2020
      Midwest
      08-01-2020 04:36 PM #17
      It’s super easy dude. I would only pay somebody to do it if I had more money than brains. Watch some vids and go for it.
    19. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      08-01-2020 06:46 PM #18
      Quote Originally Posted by ADDvanced View Post
    20. Member pontiac's Avatar
      Aug 3rd, 2009
      Nova Scotia
      Civic/Civic Si/Civic Allroad
      08-01-2020 07:35 PM #19
      https://www.autogeekonline.net/forum...tml#post313790
      Give this a read. Mike Phillips definitely knows what hes talking about when it comes to restoring paint.
    21. Member Bicycle019's Avatar
      Mar 30th, 2001
      Denver, CO
      '84 Mk1 Jetta GLI ABA S/C, '89 Vanagon Carat Whitestar, '17 Golf Alltrack, '16 GTI PP
      08-01-2020 07:56 PM #20
      Follow the steps laid out in this thread. It's shocking how well it works. It's an epic write up, but the principals are solid and you'll learn some good history about automotive refinishing.
      https://www.autogeekonline.net/forum...ge-paints.html
      On my '84 GLI with Mars Red single stage paint it was nothing less than transformational, and the paint wasn't in that bad condition. I followed the guidelines laid out in that thread and did three hand rubbed passes with Meguiars #7 Mirror Glaze to remove initial oxidization and "nourish" the paint, then it was safe to machine polished with Meguiars #9 Scratch/Swirl Remover 2.0 which plays well with the #7 and single stage paint (used a Griots G9 buffer with orange Lake Country pad), then hand waxed with Collinite 845 wax. Old school products, but for old single stage paint it looks amazing. Products were not very expensive, but it did take some time. The first coat of the Megs #7 sat on the car overnight, the two other coats for a few hours.
      Meguiars #7 - https://www.amazon.com/Meguiars-Mirr.../dp/B0002UQAM0
      Meguiars #9 - https://www.amazon.com/Meguiars-Mirr.../dp/B0002SQVX0
      Collinite 845 Wax - https://www.amazon.com/Collinite-845.../dp/B000JK2D06
      Party time, excellent.
    22. 08-01-2020 08:31 PM #21
      Damn, dude... That's stunning
    23. Member 2 doors's Avatar
      Jun 18th, 2003
      Baltimore, MD
      '19 Accord EX Hybrid, '16 e-Golf SE, '04 Sequoia SR5
      08-01-2020 11:00 PM #22
      This is the best answer for you. It just came out in the last year or so. I plan on picking one up just for the fun of it.
    24. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      08-02-2020 05:33 AM #23
      Quote Originally Posted by pontiac View Post
      Thanks
      Quote Originally Posted by Bicycle019 View Post
      Beautiful MK1. Thanks for the detailed tips. Question - did you remove any trim or doorhandles or anything or just tape/work around them?
      Quote Originally Posted by 2 doors View Post
      I was psyched to see it. It's been added to my list. I'll let you know how it works.
    25. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      08-02-2020 07:14 AM #24
      I came here to read, as I really need to do the 54 year old paint on my Bug, but I will say that yeah, you should go ahead and pull the door handles since it’s just sooooo easy on a Mk1 or Mk2. The same is true on mine, too, as a Bug’s door handle comes off the same way. It also gives the opportunity to clean and lubricate the latch mechanism.
    26. Member fireside's Avatar
      Feb 23rd, 2008
      '20 F-150 SCREW 2.7EB 4x4
      08-02-2020 09:12 AM #25
      Single stage is awesome and is by far the easiest paint type/method to correct and "bring back." Head on down to Harbor Freight, grab their better-of-the-two DA polishers, go online to DI or AutoGeek and get some Lake Country pads and start with something light like Meguiars M205. Can't really mess it up. Take your time and post results after!
      Practice on a newer car or study the heck out of YouTube videos for technique, tips, etc.
