VWVortex.com - Axle spinning intermediately
    Results 1 to 6 of 6
    Thread: Axle spinning intermediately
    1. 09-07-2020 08:46 AM #1
      I’m having some crazy axel/transmission issues on a 04 beetle 6spd. Basically in gear while driving it feeling like the car is skipping, I attached a video of the passenger side and the driver side axle. When the axle is disconnected the issue isn’t present. Both axels are new and so is the passenger side wheel bearing.
    3. 09-07-2020 03:07 PM #2
      Apparently I need 5 post to upload videos 😐
    4. 09-07-2020 03:08 PM #3
      Hopefully this goes through now....
    5. Remove Advertisements
    6. 09-07-2020 03:21 PM #4
      Took all day to figure how to upload videos but here they are
      Dec 22nd, 2016
      09-09-2020 11:45 AM #5
      looks like you have teeth missing on the diff. whether it's the pinion or crownwheel you might be able to see the ring gear if you drain the oil.
      Dec 22nd, 2016
      09-09-2020 05:14 PM #6
      forgot to ask, is it the same in every gear? including reverse?
