Anyone try a Pedal Commander on an Atlas?
3K views 3 replies 3 participants last post by  KarstGeo
#1 ·
Just curious if anyone has tried one of the Pedal Commander devices. 300 is a bit steep for it but curious on reviews from the pros on here
#2 ·
Pedal Commanders are just snake oil.
They just tell the ECM you've pushed the pedal further. So basically 25% pedal position become 50%, 50% pedal position becomes 100%, 100% Pedal position is 100%. Might not be the exact ratios, but exactly literally as it works.
Another thing to consider is that the ECM has a map that changes accelerator response based on RPM(and maybe even load) and pedal modifying boxes mess that up royally.
So save the $300 and just push your pedal further on your own.
